Hi. I plan to make a music video dvd of music I made, therefore audio quality is a first priority. When I author the dvd can I just use a straight up wav file? Will it compress my wav file into something of lesser quality? If so what format should I use for the best quality?
I think most authoring programs should be able to use wav without compressing it.
You need to select "lpcm" in the audio settings to use the highest, uncompressed setting.
Of course you have to use lower video bitrates to make it fit.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
From
https://www.videohelp.com/dvd
"Audio:48000 Hz, 32 - 1536 kbps
Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio."
That means one 16bit 48KHz stereo pair can be handled uncompressed from a camcorder or up to 8 channels if imported.
8 channels full 16bit 48KHz PCM will stream around 6,144 KHz leaving only about 3500 Kb/s for video. Don't push it if you want it to work on all DVD players.
Of course, most DVD players see only two PCM channels at a time depending on authoring. -
Thanks! It is only a stereo wav so how much bitrate does that leave for video?
Use a bitrate calculator:
https://www.videohelp.com/tools?tool=VideoHelp_Bitrate_calculatorDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
With 48KHz 16-bit/channel stereo LPCM audio (=1536Kb/s) on a DVD the maximum allowed video bitrate is 8000Kb/s as far as I know.
The max combined bitrate is 10,080kbps, and with audio at 1536kbps, that leaves a touch over 8500kbps for video (and subtitles) in theory. Of course this does not take into effect the running time of your video; just the max permissable bitrate according to the DVD spec.
If in doubt, Google it.
I need to make default uncompressed audio again!
By Artas1984 in forum AudioReplies: 1Last Post: 8th Jan 2011, 16:04 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 08:20 -
DVD to XVID and retain LPCM audio uncompressed
By rollo_tomasi in forum DVD RippingReplies: 8Last Post: 14th May 2010, 11:47 -
Join 2 uncompressed wav audio files
By kidcash in forum AudioReplies: 13Last Post: 11th May 2008, 02:15 -
Is Dolby True audio and Uncompressed PCM worth a new receiver?
By yoda313 in forum AudioReplies: 7Last Post: 20th Apr 2008, 11:25
