i want to add subtitle to an avi movie to watch movie in my dvd player which support divx files.
i used srt2bmp software but there was aproblem that when i make mux to avi file with xsub nothing is created
can any one tell me why?
and if any body know better way to do that please tell me.
Results 1 to 9 of 9
It very much depends on what player you own, and what kind (if any) of subtitles it supports. Mine do .srt subs fine, so I just add the srt to the same disc as the AVI.
/Mats -
it supports srt files but it dosen't support the language of my subtitle
when i play the movie the subtitle apears as undefined letters. -
moon214 - Please take this as a helpful suggestion because that is my intention. You joined the forum 2 days ago. Welcome. Unfortunately, you have the same problem that many new users have. You think that if you tell us too much information, no one will want to help you. Actually, the less you tell us, the less we can help you.
It would be helpful to know what your DVD player is. It would be helpful to know what language the subtitles are in, but in your case I am guessing Arabic.
I have the Philips DVP-642. It plays Divx and supports subtitles. SRT works. SUB supposedly works and they say some other format is also supported, but I don't remember which. The Latin alphabet is supported. Cyrillic works and I know this for a fact because I can read Russian and I have a Divx disc with Cyrillic subtitles and it works. I don't think this player supports any other character sets. It defitinely does not support the "CJK" (Chinese, Japanese, Korean) character sets.
It seems to me that your player does not support Arabic subtitles for Divx. You don't need to mux the subtitles into the AVI. In fact, it is actually better for them to be in a separate file. If you mux them in, it may not work, but your real problem I think is that Arabic subtitles are not supported. -
my player is samsung dvd player v 6500
it supports srt but not supports arabic characters which i want in my subtitles what can i do in this case. -
Other than live without or another DVD player? I can't think of anything.
I use AVI Recomp. It burns the subtitles directly onto the file, so you dont' have to worry about whether or not your player supports subs or not. Worth a try
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Adding subtitle to xvid without increasing file size of the .avi?
By Kromgol in forum Newbie / General discussionsReplies: 3Last Post: 19th Jul 2009, 12:03 -
how could i add arabic subtitle to avi movie?? plz help!
By abuelbeel in forum SubtitleReplies: 1Last Post: 20th Apr 2009, 13:44 -
AVI recomp error when adding subtitle
By Janey87 in forum SubtitleReplies: 1Last Post: 3rd Sep 2008, 02:47 -
Adding subtitle to a movie and use it only in a STAND-ALONE DVD player ?
By bradford in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 01:59
