Newbie trying the trial version of DVDLab.
WHAT I WANT TO HAPPEN:
1. A copyright menu appears with a 10 second timer. If user presses the title button on the remote, he exits the copyright menu immediately and goes to scene selection menu 1 (SSM1).
2. SSM1 has 6 frames that are linked to 6 chapter points in the video.
3. User navigates to any frame in SSM1 and starts playback from there.
4. User decides to exit playback so he presses the title button on the remote control. SSM1 appears.
MY PROBLEM:
The title button on the remote can only link to a root menu or a movie. Therefore I am only able to link it to the copyright menu or the video. Am unable to link the title button on the remote to SSM1.
How can I do this?
Thanks,
mks
mks -
Go to the Connections window. Right-Click on a menu object, and a popup menu will open. Toward the bottom (second last item, I believe) is UOPs and Settings. Click on this and a dialog will open. Here you can set the action for the Menu Button.
To the left of the Connections window is the toolbar. It has the arrow, connection tool etc. One of these is an M in a box. You can use this to link Movies and/or Menus to the Menu button.
This holds true for both DLP 1.x and 2.0, and is covered in the help files under Menu Button.Read my blog here.
Move Objects
Draw Connections
-Rename
-Go there
Jump Links
Button Links
Show Lines
-Rebuild transition
-Set menu as root
Add empty movie
Add empty menu
Add empty slideshow
(the items prefixed with a - above are grayed out) There is no "UOP's and Settings" shown.
To the left of the connections window there are only 4 icons:
Arrow
Box\+
Hand
There is no M in a box shown. I'm using the lowest trial version of DVDLab. Not the Studio version or the Pro version.
Thanks,
mks
how to rearrange the movies in dvdlab
By sumeshkri in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2010, 06:18 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 14:09 -
DVDlab Compared with TDA
By loster in forum Authoring (DVD)Replies: 7Last Post: 30th Dec 2007, 19:34 -
Is there any other software like dvdlab?
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 04:55 -
problem with dvdlab pro2
By postie1392 in forum Newbie / General discussionsReplies: 10Last Post: 27th Sep 2007, 06:00
