This may be a silly question, but I don't know enough about exactly what data in a file determines frame rate:
I've used Cinema Tools to conform a 25FPS clip to 23.98FPS. When I throw that conformed clip into ffmpegX, the frame rate shows as 29.97FPS. Why does that happen?
(When I drop the same clip into MPEG Streamclip, it shows as 23.976FPS. If I then export from Streamclip at 23.976--in theory outputting the same file I input--the exported file will be recognized properly in ffmpegX, and I've successfully encoded for DVD with 3:2 pulldown from that point...)
I'm interested mostly because whenever I've ignored funky/unexpected frame rates reported in ffmpegX, the output file usually stutters...
Specific advice and/or general how-frame-rates-are-recognized-by-applications info all appreciated-
Cheers,
Dan
Results 1 to 1 of 1
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 04:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
