Hello,
I am trying find the most effective and most fastest way of converting my DVDs to AVI format because whenever I try converting these files, it take hours to complete and hogs my memory while I can be doing more productive tasks on my computer. I've been using many programs so far such as AutoGK, DVD Rebuilder, SimpleDivX, and more.. but none of them convert DVDs to AVI format in few hours or less.
Is there any settings that can convert my DVDs to AVI format in at least 3-4 hours while still obtaining decent quality? What programs do you recommend using? Please let me know.
For your information, here are my current specs of my computer:
AMD Athlon 64, 3000+ (OC to 2.21 GHz)
ASRock 939Dual-SATA2
ATI Radeon 9600 XT
1GB Corsair ValueSelect DDR400 PC3200
Creative SB Live! Value
Seagate Ultra-ATA/100 120GB HDD
Seagate SATA II 300GB HDD
Thanks!
	DVD Rebuilder doesn't convert to avi. AutoGK is a s good as anything else for doing DVD to avi conversions, although you could also consider avi.net or fairusewizard as alternatives.
 That said, the encoding isn't actually done by any of these. These programs are just front ends to make your life easier in prepaing the files. The real work is done by the encoder or codec (Compressor-DeCompressor) itself. So if you choose Xvid for output, the difference between avi.net and autoGK will be negliable in most cases. Similarly if you choose Divx instead.
 CPU is about the only factor influencing the speed on a mchaine like yours. So either put a faster CPU in (or wait for Core Duo 2 to get cheaper), or get a sceond PC so you can dedicate on to encoding while you work on other things with the second PC.Read my blog here.
  Best & Fastest Tool To Cut An AVI, MP4 File In The Middle?By onesikgypo in forum LinuxReplies: 3Last Post: 12th Oct 2013, 21:07
  Converting DVDs to .avi filesBy c_woodul in forum Video ConversionReplies: 7Last Post: 28th Nov 2011, 14:05
  Converting Anime DVDs to AVI (AutoGK)By vangelon in forum DVD RippingReplies: 6Last Post: 18th Nov 2009, 04:25
  The fastest way for converting a DVD into AVIBy Menvedao in forum Video ConversionReplies: 3Last Post: 23rd Jul 2009, 12:06
  Best And Fastest Way To Convert TV Show DVDs To Divx?By patrickj0781 in forum DVD RippingReplies: 2Last Post: 9th Jun 2007, 22:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
