some of my media wont open cus file extension is not recognized. but he majority will play, but will play another file that it is not supposed to. example, try to open a song and an audiobook opens up. what could this be?
Que?
A little more detail, please...
/Mats -
an example of one of my problem files: if i try to open a mariah carey song it will play as a brian tracy audio book. This is the majority of my mp3s. They seemed to be mixed up and confused
i dont know what else to say................ -
What player(s) are you using? Also, when you're experiencing the problem of 'other' things playing when you try to play an MP3, do the 'other' files exist elsewhere on your system, or are they files you've deleted in the past? Does this happen with MP3s you create yourself?
Running Scandisk/chkdsk or another hard drive repair utility on the drive where your MP3s are stored might be a good idea, if you're hearing unexpected files that are elsewhere on your drive or that you've deleted in the past. It might mean that your files are crosslinked.
Another thing to note (and I'm not saying this is what you did) is that over file sharing services/P2P, there are reportedly people who create files with random content (static, other audio/video, even porn), then give them names of popular songs/movies to foil those looking for such things.If cameras add ten pounds, why would people want to eat them? -
i did the scandisk and nothing has changed unfortunately. the files once worked fine, i dont know what happened. any other suggestions of what it could be?
Did Scandisk give you any information/error messages? If the files are crosslinked or overwritten, Scandisk usually can't do much to restore the files to the way they were.
I can't offer many suggestions without knowing a little more information, such as the questions I asked above.
And, one more question I forgot to ask:
some of my media wont open cus file extension is not recognized.If cameras add ten pounds, why would people want to eat them? -
i did the scan while i was sleeping, when i woke there were no messages, just that the scan was complete.
the file extension that is not recognized is mp3. some mp3s are recognized while others are not. when i get file extension not recognized error i cant open the file at all.
I need help playing AC3 audio file with an AVI
By mark85h in forum Newbie / General discussionsReplies: 8Last Post: 18th Feb 2011, 15:04 -
Problem playing a .mov file with Media Player Classic - No audio
By shiningwizard in forum Software PlayingReplies: 4Last Post: 20th Sep 2008, 06:52 -
Audio but no video when playing file
By alegator in forum Software PlayingReplies: 3Last Post: 28th Mar 2008, 10:11 -
How to stop audio/sound mp3 file from playing when video is finished playin
By lindylex in forum ProgrammingReplies: 3Last Post: 14th Mar 2008, 17:36 -
Playing PCM audio within AVI file
By acid_burn in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2007, 03:27
