I am having some probs. We have some AVI files which I'd like to transfer onto a DVD so they can be played on the dvd player and watched on TV. Our burner came with Nero but when I select the AVI file it says "no compatible file found". So then I tried WinAVI but the output files produced VOB files, IFO and BUP files (and windows wont open them) in a folder Video_TS. Another folder is there called Audio_TS and it appears to be empty! Is this right? I have 2 AVI files of 649 mb and 499 mb and would like it if they were on a single DVD. Can anyone help? Thanks in advance![]()
Results 1 to 10 of 10
burn the video_Ts folder with nero, see https://www.videohelp.com/guides.php?guideid=441&howtoselect=3;25#441
the audio_ts should be empty. -
...and try something like divx2dvd or convertxtodvd instead of WinAVI.
/Mats -
Originally Posted by mats.hogberg
Originally Posted by Fluffy
/Mats -
Convertxtodvd is something you may want to have a look at
It will let you add virtually any video format, so if you have a few short AVI clips, you can add them to convertxtodvd, it will create a DVD menu after conversion and burn it to DVD or create the DVD files so you can burn the DVD using your own software
I use it to convert HDTV to DVD which its very good at, does it in one piece of software and will accept HDTV source in multiple files without having to selec each file by hand for conversion as it knows its all the same movie
Also it appears to be one of the few pieces of software that manages to be better at keeping audio in sync when converting divx/xvid to DVD, or explains very easily how to correct this if it does go out of sync -
/Mats -
I tried it out and liked it! Very easy to use except the dvd autoplayed and I wanted it to start with a menu. It must have been a box I had checked without realising it. Now I'm about the purchase the licence for it.
Best, easiest method for converting DVD files into AVI, etc.
By pcq in forum Video ConversionReplies: 6Last Post: 30th Jul 2011, 13:13 -
Converting DIVX .AVI Files to DVD using Nero Vision 8 and 9.
By nnhood in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2009, 19:09 -
converting MKV files in .avi container to dvd
By jamerican in forum MacReplies: 1Last Post: 27th Jan 2009, 10:29 -
Best settings to use when converting AVI to DVD for 624x464 files?
By Cobra281 in forum Newbie / General discussionsReplies: 5Last Post: 26th Sep 2008, 16:45 -
Problems converting Multiple .avi files w/ subtitles to DVD
By bwanis in forum MacReplies: 2Last Post: 30th Nov 2007, 13:23
