Hi
I try to read the description of
TMPGEnc
TMPGEnc Plus
TMPGEnc Xpress
Is the only difference about the file format accepted ?
or is there other main differences ?
which one of them would you recommend ?
tmpgenc is free but just a mpeg1 encoder.
tmpgenc plus has the mpeg2 encoder.
tmpgenc xpress supports more input formats and is a more user friendly for newbies.
I would recommend a faster encoder.... -
thanx for the simple answer
which fast encoder do you recommand ?
these one are all slow ? -
Hi,
All versions of Tmpgenc are slow to encode.
A good (faster) alternative is Mainconcept MPEG encoder.
Regards,
Moonstomp.Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
What does one do about multiple DVD versions?
By takearushfan in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2011, 00:57 -
Previous Versions of tsMuxeR
By DirectorSG in forum MacReplies: 2Last Post: 18th Sep 2010, 05:44 -
Mencoder versions
By tommcd64 in forum Video ConversionReplies: 1Last Post: 6th Jan 2009, 23:21 -
Chronos - why 2 versions?
By zoobie in forum DVD RippingReplies: 1Last Post: 30th Oct 2008, 04:56 -
please explain different versions of Flashget
By jimdagys in forum Video Streaming DownloadingReplies: 2Last Post: 30th Mar 2008, 18:32
