Hi, I have a few DVDs which can be merged onto a regular DVD. I used Intervideo DVDCopy 3 for that; but it did not put a menu for the DVDs in the beginning.. ie... it did not show the 2 DVDs in the beginning from where I can select which DVD i want to play. Instead, it showed all the chapters of both the DVDs as the menu.
Is there any way to rectify that problem? Is there a way to see the 2 DVDs in main menu from where we can choose which DVD we want to play...??
Thanks in advance
TitleWriter works well for what you want--->
You can use it with various ripping tools...then..it's as easy as...opening up the folder in the program...choosing a menu..it creates a modified Video_TS folder, which now includes the Menu, which can then be burned to DVD.
There's a help file called "Add A Menu" included which runs you through the procedure.
http://forum.digital-digest.com/showthread.php?t=49227 -
Small Correction Discogal -- The help link you posted is for a rather old ver of TW -- Look in the TW installed folder for Help -- They are .rtf files
creating a dvd menu
By petarone in forum Authoring (DVD)Replies: 2Last Post: 27th Dec 2010, 12:29 -
Button Command to get back to the Merged Menu
By c627627 in forum Authoring (DVD)Replies: 0Last Post: 25th Apr 2010, 14:41 -
Best software for creating dvd menu
By BNA84 in forum Authoring (DVD)Replies: 3Last Post: 5th Apr 2010, 09:50 -
Creating A DVD Menu
By 557953 in forum Authoring (DVD)Replies: 8Last Post: 19th Jun 2008, 08:41 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01
