I've been happily using Zonealarm Pro now for the past 5 years. My subscription is about to run out and they're asking $29.95 for a one year subscription. Three years ago I got two years for that price. Also, when you go to their site to renew they have options checked by default that would add another $10 to $15, such as one year for program downloads. What? I'd thought that'd be convered in the 1-year subscription. It seems like they're trying to milk users now. I'm looking for a good alternative to Zonealarm Pro in the $20 / year or less range. Any suggestions?
By the way, I dumped Norton AV several months ago in favor of avast home (which is free) and I've been exteremly happy with it. It seems that Zonelabs is doing to Zonealarm Pro the same thing that Symantec did with Norton AV a few years back.
Results 1 to 26 of 26
Kerio basic is free, or the Kerio premium version for $15
I have that. Money well spent.Want my help? Ask here! (not via PM!)
Get a firewall router. You pay once and that's it. No software to play around with and get in trouble.
I am now suing Windows Live OneCare, which is normally $50 a year for Firefall, AntiSpyware, and AntiVirus but you can find it cheaper then this.
Let me say this, I'm very pleased so far. Just make sure you have a valid version of Windows because the Antispyware part is still downloadable from their website and therefore checks. -
If you look in their forum you'll find that they were recently purchased by another company. Most of the threads point to it being all down hill from there including an update that botched up a lot of computers....Originally Posted by rkr1958
You could take a look at the Comodo Firewall. It's free and in this review at PC Magazine, the reviewer seemed to like it. I haven't tried it personally because my xp computers aren't allowed on the internet, but that's the only reason I haven't tried it.
If someone feels like test piloting it, maybe they could post back what they think of it. -
Thanks all. Both Kerio Premium and Comodo look interesting.
lordsmurf, In checking out Kerio premium I noticed that there's avast! 4 for Kerio (which costs $15/yr). Do you use avast? If so, do you use the one for Kerio? Advantages of this version over the free home one?
VegasBud, I checked out Comodo and it certainly looks promising. In providing rationale why it's free the developers / company use the same logic that the developers / company of avast free home use, to create a safe on-line environment. Directly from the Comodo website,
Thanks again.Originally Posted by Why is it free? -
I'm also using Kerio that now is owned by Sunbelt. I havent actually updated the basic version to the new Sunbelt variant and it is still fine. If you already have pop up blocking browser, and some other protection basic is may be fine. Their price is also lower than the original Kerio and before AVG to make their own firewal they were having bundles together.
BTW you might check AVG too as many people are happy with its free antivirus. -
Regarding MS Windows Live OneCare, Agnitum has a very harsh review about it.
(http://www.agnitum.com/news/onecare.php)
They claim it failed all but the simplest leak tests.
walter -
I second that. Pay once for better protection.Originally Posted by pepegot1
PC-cillin. Works well, and if you buy it from a licensed reseller on ebay, it's about $20.00 or so.
I agree it's worthless,the only one that works is the Live online scanner.Originally Posted by walter4h
I run all freeware on my systems and they work:
ZoneAlarm free,Avast free,Crap Cleaner and Ad-Aware. -
The firewall IS very simple, but the fact of the matter is if you have broadband you should be behind a firewalls router also. Between the 2 you should be perfectly fine.Originally Posted by walter4h
I'm running a DI-624 (D-Link) router with 128-Bit WEP enabled. Does that consitute a firewall router? Or are you referring to something else?Originally Posted by pepegot1
By the way, after checking around I went with the $29.95 for another year Zonealarm Pro updates. I just couldn't pull the trigger on something else. -
I would use WPA(if you have WinXP),turn off SSID and use MAC filtering.You can also adjust the firewall settings:Originally Posted by rkr1958
http://compnetworking.about.com/od/wirelesssecurity/tp/wifisecurity.htm -
Most modern routers use NAT technology which makes your router a pretty good firewall, on top of that the windows xp sp 2 has a more than good firewall by default, if you installed sp-2. I don't think you need a extra firewall. Only if you use a laptop and connect to the internet wireless you would have to care for a software firewall, if you are using a router already.Code:
If you are concern you can go to www.grc.com and test your connection for vulnerability using Shieldsup.
And please change you security encryption to WPA, you are not secure running WEP, which can be crack too easy! -
I stopped using Zone Alarm over a year ago. I couldn't do anything on the internet withour ZA blocking my access with cable internet.
I've been using a router since then and have had no problems. -
@MOVIEGEEK
I thought of this link that will explain everything for you about NAT and Firewall routers:
http://www.grc.com/sn/SN-003.htm -
I use the older Sygate Personal Firewall. Sygate's been assimilated by Symantec, who has the competing "Norton Internet Security", so it's pretty clear that SPF is dead, but you can still find the free personal edition out there. It still works fine though. I tried Kerio before and it crashed my PC silly, and won't uninstall cleanly either.
This is in addition to the NAT firewall built into my router.
Some say you don't need two firewalls, I say you do, mainly to protect against app hijacking, and just to see if any of your apps are sending packets behind your back. My SPF warns me when 1) a certain program wants to access the Internet (just set it and tell it to remember, and it'll NEVER ask you again, changeable later), 2) when a certain program has been changed, like upgrade, or virus infected, and that program loaded, 3) a certain program launched by some OTHER program wants to access the Internet (possible hijacking). So, it's still here. -
It works okay, but I think they are issuing non-working "free license" to bug you every week, to make you eventually buy it.Originally Posted by VegasBud
SingSing,
To help my sister (over the phone) with Comodo, I ended up installing it on one of my xp computers. The problem you're seeing is probably caused by not registering it. If you enter the activation code they included in the e-mail confirmation they sent you, it will register. They don't have a for-sale version of Comodo, only the freeware version, so it doesn't make sense for them to be trying to get you to buy a product they don't sell. -
Believing yourself to be secure only takes one cracker to dispel your belief. -
Yes, and the WEP is wireless encryption.Originally Posted by rkr1958Believing yourself to be secure only takes one cracker to dispel your belief.
Pretty much the same here, but no dramatic crashes. It was real cranky though. And yes, for many people an uninstall has to be done manually, including registry key deletions. I forget the exact procedure, but a search on the web for "Kerio uninstall" will give one the info.Originally Posted by kschang
I've use ZoneAlarm, Sygate, Kerio, a few others. Currently using Outpost, it blocks ads pretty well and I've had no infections since I went to it.Pull! Bang! Darn! -
If you have an old computer in the closet that you are not using anymore, you have the option to turn it into a Router/Firewall using iptables, which is the Linux built in Firewall. I used to configure the firewall-routing using an application called "GuardDog".
http://www.simonzone.com/software/guarddog/#introduction
This could help you save money.No tengo miedo a la muerte. Solo significa soñar en silencio. Un sueño que perdura por siempre. .. -
I'd suggest smoothwall instead.Originally Posted by Abbadon
http://www.smoothwall.org/
Mitsubishi VCR's - Any Good Alternatives to HS-U748 or 778
By jbd5010 in forum Capturing and VCRReplies: 1Last Post: 2nd Mar 2011, 00:29 -
ZoneAlarm Pro Firewall: Free 1 Year License
By MJA in forum ComputerReplies: 0Last Post: 18th Nov 2008, 14:25 -
Anti-virus updating after renewal date.
By cyflyer in forum ComputerReplies: 10Last Post: 5th Jun 2008, 06:51 -
Please recommend any good Nero alternatives for Vista
By driguy in forum ComputerReplies: 1Last Post: 17th Feb 2008, 15:51 -
Good time to buy a TV during the year
By Ignis in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 23:18
