I have been using SVCD2DVD for some time with out any problems. Now I have created three DVDs that stop before the end of the program. I appears that I am missing the last four or five minutes. I have not changed anything in the program. Any ideas?
paparay
Can you attach your log from this run? Logs are kept in the Logs folder under where you installed the program.
I did not know if you needed more than one so here is another
svcd2dvdlog-20060731203322.txtpaparay -
It is because you have FAT32 filesystem on your G drive. A single file can be no more that 4GB on FAT32 - that is why you miss the end of the movie.
Solution: Use a different (NTFS) drive or convert your G drive from FAT32 to NTFS.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Only convert the first 10 minutes or so ...
By GMUET in forum ffmpegX general discussionReplies: 4Last Post: 8th Jun 2011, 15:13 -
20 minutes to burn a DVD!
By persephone in forum DVD & Blu-ray WritersReplies: 22Last Post: 9th Dec 2010, 15:12 -
Creating Chapters every few minutes
By Subhash in forum Authoring (DVD)Replies: 23Last Post: 6th Mar 2010, 10:44 -
How to shut down harddrives after 20 minutes
By mysts in forum ComputerReplies: 2Last Post: 20th Jan 2010, 03:19 -
latest few minutes missing on DVD
By coxy in forum Newbie / General discussionsReplies: 8Last Post: 5th Jul 2007, 03:47
