I needed to convert some songs off of a CD from AIFF to WAV for a video project. I didn't want to have to open up iTunes, change the default encoder, and tell it to import the songs, then delete them from iTunes, yada yada yada. (The songs are not mine, but for a video that I am making for the owner of the songs)
I thought that it might be best to use ffmpegX instead. That way I could have all the songs being converted at the same time, without any of the iTunes stuff. But ffmpegX claimed that the AIFF files were of Unknown Type.
Anyone else think that is kind of strange?
ffmpegX reads my AIFF file fine, however there is no 'convert to WAV' selection.
How did you think to convert all the songs at the same time? Afaik, each file conversion has to be started individually. Unlike iTunes, where you can drag-n-drop all your songs in a playlist and let it process them all consecutive. Seems quite efficient to me.
Audacity, iTunes, and probably about fifty others. Do a search at macupdate.com for "audio convert".
Case: I meant that I could start all of them, and they would finish faster than iTunes's approach of starting each one individually and adding it to the Library. In any case I'll try ffmpegX again, perhaps not directly from the CD.
Thanks everyone.
AIFF output option
By supportpartners in forum ffmpegX general discussionReplies: 1Last Post: 29th Nov 2011, 12:29 -
AIFF to AC3
By danielmak in forum MacReplies: 9Last Post: 13th Feb 2010, 23:31 -
DVD Decrypter doens't see media
By happydog500 in forum AudioReplies: 22Last Post: 28th Jul 2009, 23:41 -
AC3 -> AIFF, and AOB -> AIFF for Jaguar 10.5.6?
By DeadSirius in forum MacReplies: 4Last Post: 29th Dec 2008, 15:54 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 14:07
