Results 1 to 9 of 9
    Jul 2006
    I have D/L some MP3 files and I would like to put them through a graphic equaliser , convert them to WAV so that they will play on any CD player (am I right ) and then burn them. I have Nero 6 and 7 and Audacity with MP3 payer.
    Mar 2006
    Australia
    Put then through a graphic equalizer if you wish,then use nero to make an audio cd.
    Just add your mp3 and nero will convert them automatically,you'll end up with a cd audio (.cda)playable on any cd player.
    Jul 2006
    I am new to all this and I am not sure how to put the files through a equaliser before burning the CD. I can play the MP3 files through real player which has a equaliser.
    Apr 2004
    Miskatonic U
    Load them into an audio application that has an eq tool, adjust as necessary, then save out as wav. Burn to CD from there
    Read my blog here.
  5. Take a look at dBpowerAMP. It costs about $14 to register the PowerPack, but then you can convert from one audio format to another while applying DSP affects like "Graphic Equalizer" and "Volume Normalize".
    -drjtech
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  6. Goldwave,Nero Wave Editor and Audacity have tools where you can boost frequencies,the EQ's on players only adjust what you hear on the PC.
    Jul 2006
    So If I load it into Audacity for example will the saved files be processed through the equaliser or just as I hear it on the PC.
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    They will be processed through Audacity's equaliser, which you can listen to as you adjust until you are happy.
    Read my blog here.
    Jul 2006
    OK thanks every one for your help I will have a go at the weekend
