Results 1 to 9 of 9
  1. I have 3 Lite-On DVD drives in my computer is it possible to add a codec that would allow them to read a DVD RAM disk?
    1 - LWD-811S
    2 - LTC-48161H
    3 - SOHW-1633S
  2. NO_!,,you need a drive that will play them, LG are the best known for this.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  3. Panasonics read them too.
    Nov 2002
    But it has to be a DVD-RAM compatible drive.
  5. Thanks everyone, that's what I needed to know.
    Jan 2004
    Yes to needing a ram drive first. Check ou https://www.videohelp.com/dvdwriters and select Ram for a list
    say whaaaat?
    I recall several years ago using a panasonic dvd camcorder that recorded to mini dvd-ram discs. I installed a driver on my machine and was able to copy the .vro files to my pc for editing.
  8. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Either it was not truely dvd-ram disc or your drive would read dvd-ram disc's.
    Maybe you needed something to read the vro files on the disc.
    It is a totaly diff. disc so the drive has to be physically capable of reading ram disc's.
    It would be like trying to read a dvd-rom on a cd only burner.
  9. Preservationist davideck's Avatar
    Feb 2003
    USA
    Pioneer 110
