Hi All, how could I convert a .flac audio file into a common one?
Results 1 to 11 of 11
Google "decode FLAC"
/Mats -
I'd have to say that flac is pretty common, possibly the most common lossless format.
I would like to create a CD audio and hear it in a common cd player.
please help! -
Never heard of. What's wrong with FLAC (the encoder/decoder, not the format)?
/Mats -
Try DBPowerAmp, or my favorite Trader's Little Helper to decode your FLAC files. Or you can just play them using Foobar 2000 and other players.
Darryl -
There is a Nero plugin to use FLAC files when creating audio CDs. Just google for it and you will find it. Don't need to convert it.
Oh yeah, I just remembered. If you make a cuesheet, you can burn FLAC files directly using Burrrn (free).
Darryl -
You do not *have* to use a cue sheet. Unless you are super picky, the only reason to use a cue sheet would be if you have a single large .flac file (image) of all the tracks from the cd. Then a cue would be necessary to point where each track begins/ends. Burrrn is a great choice. www.burrrn.netOriginally Posted by dphirschler
Foobar2000 is also an excellent choice for converting (although it is more of an advanced program due to some of the setup required). www.foobar2000.org
Burrrn is the easiest route. If you want help setting up foobar (which is also an excellent player), I can provide some help. For the more advanced features, try www.hydrogenaudio.org
Some Links:
FLAC home page:
http://flac.sourceforge.net/
FLAC wiki:
http://en.wikipedia.org/wiki/FLACSome people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Foobar2000 you can just select the files, right click-->convert-->write audio CD. Needs the CD burning plugin plus Nero installed though.
FLAC into AVI file
By JOHNINA in forum Video ConversionReplies: 2Last Post: 5th Sep 2010, 20:01 -
Converting .flac to .aiff - retaining file name
By macbuz in forum AudioReplies: 1Last Post: 21st Nov 2009, 20:02 -
how to split a FLAC file?
By tomchook in forum AudioReplies: 4Last Post: 9th Mar 2008, 22:04 -
FLAC file format question
By Neil_2004 in forum Video ConversionReplies: 3Last Post: 25th Dec 2007, 10:47 -
what is flac file?
By aruwin in forum AudioReplies: 11Last Post: 19th Nov 2007, 07:33
