I have downloaded an avi file, I can play it with the computer but the audio doesn't play on my standalone divx player. I would like to reprocess just the audio and change it from 48.000 to 44.000. I have tried with virtual dub, but I always get a file which is double the size of the original.
Can anybody suggest what the correct settings are to leave the video as it is and reprocess only the audio?
Make sure your video is set to Direct Stream Copy in virtualdub, so only the audio is processed. I am guessing that you are also probably creating Uncompressed PCM audio. Make sure you actually set some type of compression.
What player do you have ? I know mine will handle 48kHz audio without any problems.
Before doing too much work on it, post a g-spot or avicodec output of the file.Read my blog here.
Thanks for your help.
Normally I can play 48kHz, but not this file. I have converted the audio to 44kHz and it plays perfectly. The file is twice the size of the original, maybe because I reprocessed the video too or chose the wrong settings for the audio. What compression/codec can I use to reduce the file size and be sure my DVD player will read it? -
Like I said, leave video in Direct Stream Copy, and it won't be changed. Set you audio to something like MP3 @ 128 kbps and your file size should similar. I don't have any details about the original file, so I can't tell you how close it will be. If you know the details of the original audio, use the same settings.
Read my blog here.
Thank you for your help. Now it works and is the same size. Thanks again
AVI with AAC audio to AVI with MP3 audio
By Neroon in forum Video ConversionReplies: 6Last Post: 30th Jun 2010, 08:15 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
Dual audio AVI to singl audio AVI.
By Benhermies in forum EditingReplies: 8Last Post: 20th Aug 2008, 20:44 -
Editing an AVI file so I am just left with the VIDEO Avi (No Audio)
By incrediblej in forum EditingReplies: 6Last Post: 26th Mar 2008, 19:16 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23
