I follow everything from the tutorial, and got the full version of panasonic encoder plugin. After everything is all setup and ready to encode, but it stopped after 2 frames. Anyone know why or did I do something wrong?
well the bad think about Bakers guide is that it only supports PAl conversion and not NTSC..when you are encodeing to NTSC with DVDx and Panasonic it only encodes 2 frames
I don't seem to have any problems with encoding to NTSC with DVDx. However, I don't use that Panasonic thing...what is that for any way?
the PAnasonic Mpeg 1 Encoder Plug-in a better encoder and gives beter quality then the bulit in Encoder
How do I fit a DVD on one VCD with DVDx 4.0?
By Xoanon in forum DVD RippingReplies: 5Last Post: 27th Apr 2012, 02:20 -
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 12:50 -
Having trouble using DVDx to rip to .mpg or .avi
By waldothewonderboy in forum DVD RippingReplies: 19Last Post: 30th Aug 2010, 03:48 -
Rip audio from VCD
By miamicanes in forum AudioReplies: 9Last Post: 4th Aug 2010, 08:04 -
help rip vcd
By Mjzchild in forum Authoring (VCD/SVCD)Replies: 1Last Post: 28th Jun 2007, 02:39
