  1. what program do you use to get your movie files into 2 parts? for instance, if your movie cant be burned on 1 cd and u cant overburn then what programs can one use to get the movie split? ive tried some but it takes alot of time so thought you had any program you could recommend...?
    abc
    Apr 2004
    Miskatonic U
    Virtualdub in Direct Stream Copy mode
    Read my blog here.
  3. VirtualDubMod is a little more useful as it shows you the byte position as well as the frame number within the file.
