I'm new to cameras.I have a mini dv camera. but I have some problems. for example which resolution and which pixel aspect ratio does dv camera use when recording tape? how can I understand these? I will be very glad if someone helps me about these topic.
123456
DV follows Rec-601 scalings but with 720x576/480 PAR same as DVD for 4:3 and 16:9.
720x576/480 25/29.97fps 576i/480i
with PCM audio 2track 16bit 48kHz, 4track 12bit 32KHz
http://people.csail.mit.edu/tbuehler/video/dv.html
http://www.adamwilt.com/DV.html
http://www.mir.com/DMG/aspect.html
Progressive 480p can be handled with special technique (google 2:3:3:2)
or see http://www.adamwilt.com/24p/ -
thanks for reply but I'm new to videos. if you tell these more clear. I will be very happy.
for example:
which resolution and pixel aspect ratio does my mini dv use before I transfer the video from camera to computer?I have pal mini dv 16:9
in pal dv format :720x576 resolution and 118:81 pixel aspect ratio
but I want to learn how video is recorded to tape?
are they same or different where and how can I learn?
at the same time can you give more information about Rec-601 scalings?
if some one helps me I will be very glad.123456 -
PAL DV is recorded at 720 x 576, whether the image is 4:3 or 16:9. NTSC is recorded at 720 x 480, again, for both 4:3 and 16:9
You can add this to the articles list above for some basics.
http://en.wikipedia.org/wiki/DVRead my blog here.
Key Concept -- pixels aren't square for DV, DVD, HDV (for 1440x1080i 16:9)
CCIR-601 defined the sampling and raster formats originally
This evolved to ITU-R BT.601 which was the basis for DV, DVD, MPeg and SD digital broadcasting.
http://en.wikipedia.org/wiki/CCIR_601
http://www.ebu.ch/en/technical/trev/trev_304-rec601_wood.pdf -
Don't feel bad I've been around for while and I still barely comphrehend some of the stuff he says.Originally Posted by matriplex
What's on tape or your computer is an identical copy, if you transfer as DV-AVI. To add, when you transfer there is flag that says this is 16:9 for example if you recodred in 16:9. Once the file is on your computer your software video player will usually respect this flag and adjust the aspect accordingly. Same for DVD....but I want to learn how video is recorded to tape?
Video Properties
By shockgolf in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2011, 00:59 -
Hello, new here. Need help with time properties!
By Gypsy Eyes in forum Newbie / General discussionsReplies: 7Last Post: 27th Jan 2011, 19:05 -
Help with pc admin properties
By SIRCOOKS in forum ComputerReplies: 7Last Post: 29th May 2008, 18:54 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 14:48 -
MPEG properties
By tonyaldr in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2007, 23:42
