Hi All,
I'm considering buying either a 970 or DVPNS90V. Anyone know if both can handle dual layer DVDRs? I thought I read here the Oppo can, what about the Sony? Any other comments from owners of either re performance & quality are appteciated. Thsnks!
Most players can handle DL media (most issues are with older models).
If you have DVI or HDMI inputs on your TV, get the Oppo 971.Google is your Friend -
Having experimented with both +R and -R DL, I would suggest you only use +R DL for best compatibility. -R DL is a kludge to make it work and my Philips DVP-642 doesn't like the -R DL discs very much, but it plays the +R DL discs OK. Also, you have to be VERY careful how you burn -R DL discs. I don't know if it's still true, but at one time not too long ago, Nero was incapable of correctly burning a -R DL disc. It would always set the layer break in the wrong place. The only way I know to burn that works is to use PgcEdit to create an ISO image and burn with ImgBurn or DVDDecrypter.
Nero still has numerous issues with DL media.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Question about either of my Sony drives being able to burn dual layer discs
By Puppets86 in forum DVD RippingReplies: 51Last Post: 9th Jun 2010, 18:04 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
Questions about OPPO DV-970 HD
By animefan in forum DVD & Blu-ray PlayersReplies: 10Last Post: 12th May 2007, 07:27
