Someone just posted the entire 22-episode series of an Australian TV show that I've been waiting for. Unfortunately, they screwed something up. I suspect that the aspect ratio should have been widescreen, but they stretched it to fit the screen, and everyone is thin and tall.
Are there any utilities that I can use to modify the aspect ratio?
Results 1 to 10 of 10
Originally Posted by guns1inger
The application failed to initialize properly. Click on OK to terminate the applicaiton. -
Could be that the files already have the PAR set correctly and whatever you are using for playback is ignoring it. Because that is all MPEG4Modifier does; sets a flag for the AR. It is upto the player/decoder to resize.
Also, there was a java port if you don't like .NET. Next version will require .NET 2.0 to. -
A long time ago, I installed MS's .net framework, and it tried taking over my computer. I don't think I'll try that one again. Is there anything else that might do this?
For playback, I've tried the following:
Windows Media Player
Intervideo WinDVD 6
Philips standalone dvd player (playing .avi files)
Above, playing DVD that was converted using VSO ConvertXtoDVD -
Never heard of .NET doing anything particularly bad. As I said there is a java port. So if you don't like .NET you could try that.
I hope nobody yells at me for being a complete bozo, but when I downloaded these tv episodes, they had a suffix of ".divx". I changed them to ".avi". Was this a mistake?
I found an extra machine and loaded the .net framework on it and tried mpeg4modifier. It seems to work, but I can't find any documentation, and I'm not sure what to do. I browse and open my .avi file. There is an aspect ratio radio-select area. I'm assuming that I should choose one of these. So far, I've tried 16:9 NTSC under the "Pixal AR" column and 16:9 under the "Display AR" option. I click on save and choose a name for the file. It grinds for a while and tells me that the file was successfully saved. But the new file has the same aspect ratio as the old.
GIVEN UP,Now how to convert Mpeg 2 to a clean AVI with same aspect ratio ??
By mudh in forum Video ConversionReplies: 4Last Post: 11th Oct 2011, 16:04 -
How to convert squashed DVD aspect ratio back to normal??
By EricBalir in forum Video ConversionReplies: 5Last Post: 9th Sep 2011, 22:36 -
Trying to convert .mov to .flv - aspect ratio problems
By Graeck in forum ffmpegX general discussionReplies: 12Last Post: 21st Oct 2010, 17:55 -
Easiest, fastest way to convert MKV to Blu Ray with 1080p aspect ratio
By jfk8680 in forum Authoring (Blu-ray)Replies: 3Last Post: 12th Apr 2010, 23:07 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30
