  1. Hi
    I have an issue that I am not sure where to post. I have captured a 4Hr VHS tape with Cyberlink PowerDirector. I captured at DVD HQ (720 x 576 (8000kbps)).
    I have edited (Cut, Added Transistions, etc) the whole 4 hours and the total length now is 1 hour 50 mins.
    I for the life of me cannot get this to look good on a DVD.
    I initially was getting horizontal lines but afer reading here found that by de-multiplexing, using restream to change the field order and multiplexing that I could get rid of that.
    It worked.
    BUT
    Why is the DVD jittery ?
    I have heaps of bitrate. (8000kbps)
    I must have the field order correct because the pic is significantly better.
    This is really killin me. I have read so many articles on this site and forum threads but I cannot really find anything similar. Other people have not enough bitrate etc but I dont seem to qualify for this reason.
    Anything you guys can suggest would really be appreciated.
    Be gentle.
    Oh, I forgot to add that I have tried DVD Author 2 to author and Cyberlinks Own PowerProducer with no difference in quality.
    Apr 2004
    Miskatonic U
    At a guess, you have tried to solve what was not a problem, and in doing so, created one. The horizontal lines were probably interlacing. It is often normal to see them on a PC monitor, however you would not see them on a TV. By using restream to alter the field order, you have cause the jittery footage by having the interlaced fields nowplaying incorrectly. I suspect if you reverse the field order again, and create a DVD for testing on your TV, you will find that see neither the jittery image, nor the interlace lines.
    Read my blog here.
  3. Sorry, I should have mentioned that I was watching this on my normal TV and not on the computer screen.
    Apr 2004
    Miskatonic U
    I would put them back and watch again
    Read my blog here.
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Thje first thing I would do is capture a short clip preferably something with a lot of motion and burn it right to DVD. Make sure the authoring application you are usin is not reencoding the video. This last part is the most important...
  6. Thanks I will try that
