Hi
I try to convert a mpg2 to mpg2 (with different size and bitrate) using tmpgenc
the software seem to only see the video it does not want to take the audio in this file
The audio is playing no problem in windows media player
avi codec is telling me that the audio codec is a ac3 dvm.
I try to extract the audio content of the source using goldwave but I wont open the sound from the file either.
So anyone know what i can do to make tmpgenc take the audio for this conversion ?
TMPGEnc encoder can't use AC3. But you can save out the AC3 and combine it back when you author to DVD format, along with your converted video.
EDIT: You can extract the AC3 with VirtualDub Mod.
Extract the AC3 from the Video:
Start Virtualdubmod.
1. Open the video, File-Open
2. Select Streams->Video list
3. Select Demux and save the ac3 audio.
Then select your MPEG video in your authoring program, and your AC3 audio. I use TDA for this.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Is there a way to batch normalize audio of MPG2
By mehnihma in forum AudioReplies: 3Last Post: 6th Mar 2010, 01:15 -
Convert video from 2-disc dvd to one mpg2
By gamingexpert13 in forum Video ConversionReplies: 12Last Post: 17th Oct 2007, 05:59 -
Convert mpg2 to mpg for Movie Maker
By Cattis in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 14:01 -
Q: Adaptec AVC-2310 MPG2 Capture - Need: Shrink/Fit to DVD, Redo Audio
By jpneok in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jun 2007, 20:06
