Hello
I have some games installed on my computer, now most of them uninstall with ease but 2 specific ones will not uninstall no matter what I do. I've inserted the disc and tried to uninstall them and ive also tried manuelly through add/remove programs. When I click remove in add/remove programs the screen just flashes and nothing happenes same thing if I try change. All my other programs also remove without any problem can someone please help me uninstall these programs.
Originally Posted by wwervd316
a couple of things to do...
1. go into safe mode and try using add/remove there... many times if a file is loaded a program can not be uninstalled.. and possibly elements of these games maybe running and that why you can't uninstall themm
2. if they were recently installed.... use your system restore and pick a date that predates the installation.... that will work....
3. go to the manufacutrer website and see if they have any special instructions for removal.... you might want to take a look at the readme file of the game many times they will have specials on remeoval.....
4. now those are the most common things I can think of at the moment i am sure there ways like using a good uninstaller program there of free one out there...... and i am sure other will suggest there favorite meathod of removing stubborn programs.....
5. now the very last resort!!! very last... and that is manually removing.. that means going into the registry and manually removing alll reference to the game! but only do this if you have the confidence and some knowledge of the registry... if you go this route make a backup of the registry before editing!!!..... just in case something goes wrong... -
Sorry I was in a rush and I guess I forgot to put the games in. They were CSI Dark Motives and Driv3r.
question about difficulty in uninstalling file
By jimdagys in forum ComputerReplies: 3Last Post: 28th Mar 2008, 09:52 -
Uninstalling or reinstalling nero
By b3cko in forum ComputerReplies: 3Last Post: 10th Jan 2008, 08:37 -
Uninstalling this utorrent program
By vipertongn in forum ComputerReplies: 7Last Post: 5th Aug 2007, 07:17 -
Trouble uninstalling dvd43 - help
By NitroxAZ in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2007, 22:43 -
no audio device after uninstalling antivirus?
By Rudyard in forum ComputerReplies: 4Last Post: 23rd May 2007, 21:19
