Trying to make a movie with three hundreds of .mpg files from Sony HDD Camcorder, files size totaling 3.7GB. Tried several softwares and failed
ImageMixer(Sony) - only allows 98 clips. Tried using Adobe PE2 and Nero Movie Maker to join (Export) them. The result is blury video. Tried trial versions of MovieJoiner or MpgJoiner which failed to join clips.
Pinnacle - crashes at about 110 clips. If small number of clips, can't have both standard and wide-screen
Adobe PE2 - crashes at bout 130 clips.
TMPGen - only allows 99 clips per track. better then previous two. But generate all kinds of error message if too many clips. Again I have not found a working "Joiner" to combine mgp clips into mgp clip with no degradation.
Help is greatly appreciated
Have you tried Ulead DVD movie Factory? I use it with multiple .mpg files with no problem (never tried 300 tho!)
Chuck Barris - CIA hitman. You better believe it. -
Ulead DVD movie factory will also make DVD directly from your camcorder.
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 02:53 -
how to make a dvd with lot of small video files?
By sumeshkri in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2010, 11:13 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
burning 300 mpg video files on DVD?
By twister6 in forum Authoring (DVD)Replies: 3Last Post: 2nd Nov 2008, 20:02 -
Easy Freeware to make DVDs out of mpg and avi files?
By gail22 in forum Authoring (DVD)Replies: 13Last Post: 15th Oct 2007, 19:31
