What is the best image size to use for pics that will be put into a slideshow and authored to DVD? I've used 720X480 in the past and it didn't quite fit the screen like I thought it would have. I understand that different TV's have different viewable areas, but is that the only thing that would cause a 720X480 pic not to fit perfectly?
I'll be using Video Studio 9. I'm not sure if VS9 will stretch or shrink down pics that are too large or too small, but I have over 100 pics to do so I'd like to get it right the first time.![]()
This is NTSC.
I asked a similar question in the past and I didn't really get the answer I was looking for.
Thank you.
44E
Best to use 4x3 format and no need to resize from your camera.
The Ulead Forum will give you a lot more answers.
http://phpbb.ulead.com.tw/EN/viewforum.php?f=1&sid=2e9c1715792564f0f84eaf4f305adaa2 -
I prep all of my images in Photoshop first to the correct size. This has a number of advantages, including the ability to crop, colour match and perform overall corrections in a an environment that is better suited to photographic work, and the fact that Photoshop generally resizes much better than most video programs. The only time I leave the photographs bigger than video res when doing slideshows is when I am going to be panning or zooming (the so-called Ken Burn's Effect).
Read my blog here.
The correct size. Do you resize them to 720X480, or the equivalent for PAL?Originally Posted by guns1inger
Do you know what size the safe zone is for TV viewing of 4:3?
Thanks.44E -
I use 1024x768 inserting some Gaussian Blur in PS IF the image is too sharp.
It works!
Need help with projector image size...
By mason dixon in forum Media Center PC / MediaCentersReplies: 1Last Post: 8th Feb 2011, 10:37 -
mpg image wrong 'size'
By HMH in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 16th Sep 2010, 17:49 -
Image PPI -> DVD slideshow...does it matter?
By Grunberg in forum Authoring (DVD)Replies: 1Last Post: 12th Nov 2007, 18:06 -
Using Avisynth Transition PlugIn For AVI Still Image Slideshow
By wiseant in forum Video ConversionReplies: 4Last Post: 24th Oct 2007, 13:45 -
Image Size
By koberulz in forum Newbie / General discussionsReplies: 6Last Post: 20th Jun 2007, 04:49
