i ave had this for a year and a half now so it's out of waranty.I was playing a dvd and the dvd stopped and it said "BLOCKED" In the display panel of my dvd player so i turned it off and then a message "STARTUP" comes up for a about five seconds and then the dvd player shuts down and five seconds later start up comes up again.None of the funtions work in the dvd but i got the drawer open today but i was wondering if any one knew how to fix it.Pease helpthanks in advance
I have a DVDR610/05 with the usual BLOCKED symptom. When pressing eject it briefly tries to open and then closes again with BLOCKED message. It will not read any disc.
One recommended solution is the SABL IC repair kit available from Signals UK for about £13. I see that at least some of the mods in the SABL IC repair kit (order 12NC: 9965 000 29182) have been fitted to mine as the caps and diode are there. But the SA56202TW IC has a mark on it that looks like a burnt spot. It has the numbers on it CD1783 03 and TPN0443 Y or TPN0449 Y. Is this a pre or post week 0512 chip?
The Prod. No. on back of case is VN1E0448 108452
Some other chips on the drive board are dated 0528 so looks like the set was manufactured some time after that week.
So, assuming the SABL is the new type, is there any record of the new ones failing and are the fault symptoms the same as for the old one? Is there any point in my buying a12NC: 9965 000 29182 kit and fitting it?
Some others posting elsewhere expressed doubts about changing such an IC with such small leads, but as an electronic engineer, I think I can do it.
Help with Philips DVP3560
By dfisher052 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 2nd Dec 2010, 13:06 -
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 10:15 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 16:06 -
Philips PET712
By marcbilodeau in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Sep 2008, 17:25 -
Philips WOWvx 3D tv
By gll99 in forum DVB / IPTVReplies: 1Last Post: 5th Aug 2008, 00:47
thanks in advance
