    Nov 2005
    Hey, all. I have a standard NTSC mpeg-2 video ready to go for a DVD. The problem is, I'd like to add an audio track without re-encoding either stream--and still have a single file (not *.VOB) playable in, say, Media Player and Winamp. Is that possible? If so, how do I do it?
    Any help would be much appreciated. Thanks!
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    What do you mean by "append"? Add more audio at the end, or add another audio track? If the former - hard, but can be done, depending on audio format. If the latter - Most authoring apps should allow you to add audio tracks.
    /Mats
    Nov 2005
    Sorry, "append" was the wrong word. I don't want to add audio to the end, but rather add synched audio to the video. I normally use TMPGEnc, and it does not seem to allow that sort of thing. VirtualDub does, but only for AVI files.
    ImagoMPEG-Muxer
    or
    tmpgenc -> file->mpeg tools->multiplexing and think you can add several audio sources(mpeg audio or ac3).
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    TDA doesn't support >1 audio track, it seems... But here's a list of the authoring apps that do!
    /Mats
  6. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    The newer TDA 2.0 supports 2 seperate audio tracks.
    The older TDA versions only support a so called bilingual audio track. (mono audio track in the left and right channel)
