Hi
I am trying to put an MPEG into TMPGEnc to burn onto DVD, it comes up with the following error message,
'*The video resolution 320x240 cannot be used for a standard DVD.
For a standard DVD you can only use the following resolutions:
352x240 352x480 704x480 720x480 pixels (NTSC format only)
352x288 352x576 704x576 720x576 pixels (PAL format only)'
*The video framerate 25 fps cannot be used with the resolution 320x240
This framerate can only be used with the following resolutions:
Can anyone give me any clues how to get around this ???
Cheers
Mike
Results 1 to 9 of 9
I have converted the MPEG to DVD VOB files using WINAV but it still comes up with the same error, is this what you meant ??
Depends on what you start with. There's a lot of guides on how to convert almost any format to DVD if you take a look under CONVERT left, and use the excellent format conversion selector.
/Mats -
320x240....is this for a portable device? I downloaded and installed Super to do the conversion for me. So far it has converted xvid and vob to h.264 format. Looks and sounds fine on my ipod screen, although it is tiny. Better for tv shows than for full length movies.
Did I mention I bought an ipod yesterday?TANSTAAFL -
u can change the header so u can trick the encoder that its dvd res...some dvd players will play the dvd fine...thats if u dont want to re-encode the whole video
check out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 20:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 22:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 22:00 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 12:05
