Hello,
I have joined two movies using DVD shrink. Now how do I make a title menu listing both the movie titles, so that I can choose the movie I want to play in my DVD Player.
The easiest would be to reauthor using TDA - Import DVD Video. Or simply use the remote to select title.
/Mats -
The Womble MPEG Video Wizard DVD is an easy DVD authoring. Drag your movies into DVD Maker, set Chapters, then select the 'Text Template'. Edit the Chapter Text title listing your movies. Finally, export it.
But the only thing that I am not satisfied is The MVW DVD cannot support burn the VIDEO_TS folder to Disc. I must use Nero to do that so.
I think the Womble video wizard DVD is suit for you. Try it. Wish to help you.
nightcat
AVStoDVD limit the number of chapters/titles in Menu
By Nirvana_417 in forum Authoring (DVD)Replies: 3Last Post: 4th Feb 2012, 11:40 -
Error BD REBUILDER menu are not seen titles after the compression.
By malpa in forum Authoring (Blu-ray)Replies: 0Last Post: 6th Jan 2010, 22:18 -
Multiple blu ray titles-No menu with AVCHDcoder or MultiAVCHD?
By thegeeman in forum Authoring (Blu-ray)Replies: 6Last Post: 22nd Sep 2009, 08:22 -
DVD - 5 Titles, No Menu -- How to loop back from 5 to 1 at end??
By cykedout in forum Authoring (DVD)Replies: 3Last Post: 27th May 2008, 22:10 -
goal: menu with 4 titles with separate menu for one of them?
By spiritgumm in forum Authoring (DVD)Replies: 27Last Post: 22nd Oct 2007, 13:47
