Can someone tell me how to get the absolute best quality besides the actual vob file from a DVD, right now I am using Avi DIVX Menucoder 2-pass with all the rest of the options enabled, I click best for the video bitrate, anything better?
Results 1 to 11 of 11
You could give "MP4 H.264 x264" a try. Is there any particular reason you are looking for something other than AVI DivX mencoder? Anything about that codec that you're unhappy with?
"Absolute best" is an impossible question. Your 'best' may be very different from what I think is 'best', because we all have different criteria. E.g., do you want a small file size (smaller is better?) or do you want a quality as close as possible to the original? How close is good enough? Do you need a specified file size? Do you need compatibility with a certain device? Do you need objective video quality (PSNR/VQM/SSIM) or do you have subjective opinions on video quality. How do you tell two very good but different encodings apart? If someone says codec X is better than codec Y, how could he prove that to you? What are you looking for in a 'best' solution?
There's also a funny thread about 'Best' in the Feedback forum.
With Xvid use single pass, target quantizer mode with the quantizer set to 2 (constant quality encoding). Use the same 720x480 frame size and aspect ratio as the DVD. If the file size that delivers is too large, and you think you can live with lesser quality, use a higher quantizer value, 3, 4, 5...
As Case pointed out, h.264 or x.264 (open source equivalent) will get you smaller file sizes. But it will take much longer to encode.
At Q=1 the results will be nearly indistinguishable from the source. But the result may be a file larger than the MPEG2 source.
At Q=2 the results will still be nearly identical to the source. The final file size will probably be about half the size of an MPEG2 source.
At Q=3 the result will show a little macroblocking if you look at enlarged still frames. They won't be noticeable at normal playback speed. The file will be smaller.
As you use higher quantizer values the image quality will get worse and the file will get smaller.
Note that Xvid and Divx encode B-VOPs with higher quantizer values (lower image quality) than I and P frames. If you want every frame to have the highest quality, disable B-VOPs. (Actually, Xvid allows you to use the same quantizer for B-VOPs but there's no point in doing this -- the result will visually be the same as an encoding without B-VOPs.) But again, at normal playback speeds you're not likely to notice much of a difference.
With Target Quantizer (constant quality) encoding you know the quality of the output but not the file size. With 2-pass VBR you know the file size of the output but not the quality. If you create an Xvid file using constant quantizer encoding, then create another using 2-pass encoding with the same average bitrate (ie, the same file size), the image quality will be nearly identical.
Originally Posted by jagabo
Jagabo, i do not see this option. I am using ffmpegX v0.0.9x. I only see tabs for Summary, Video, Audio, Filters, Options and Tools. I do not see "Encoding Type" or "Target Bitrate/Quantizer" ... are these controls in a newer version?
Sorry, I had forgotten this thread was regarding ffmpegx. I don't know if ffmpegx gives you access to target quantizer encoding.
Want to rip from interlaced DVD's in highest/same quality!
By DARkTYranno in forum DVD RippingReplies: 17Last Post: 22nd Feb 2012, 16:05 -
Convert to DVD (VOB) Highest Quality converter?
By Mark97213 in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2011, 10:47 -
Highest Quality XVID to DVD
By Merkaba188 in forum Video ConversionReplies: 10Last Post: 1st Jan 2009, 21:58 -
DVD to H264 - Highest Quality - Which is the best software to use?
By fgtan in forum DVD RippingReplies: 4Last Post: 29th Nov 2007, 08:37 -
Highest Quality DVD+R DL Printable discs?
By Cyrax9 in forum MediaReplies: 3Last Post: 17th Jun 2007, 22:15
