I have some avi clips that I've converted to MPEG2 to make DVDs. They play at normal speed, but, the sound is like the sound in a [/i]very, very slow motion clip.
I probably should also say that when these AVI clips were played in VLC media player before conversion, the sound was kind of choppy and staticky. However, other AVI clips from the same source also sounded choppy before conversion when played in VLC, and also after conversion when played in Nero Showtime, but when they were finally burned to DVD, the resulting DVD sounded just fine.
Ideas?
You might take the problematic file and drop it into Gspot 2.52 and compare it with a known good file. Check particularly for MP3 VBR audio, or to a lesser extent AC3 audio. If you find either, or nothing, you might want to drop one into VirtualDub and see what it says. You can also 'Scan video stream for errors' in VD and see what comes up.
What it really sounds like is a bad framerate conversion, like 23.976 to 25 or 29.970 or something similar. Comparing them in Gspot should show that.
I have a problem with mp4 files in virtualdub, slow motion audio.
By barbur in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2012, 14:16 -
Using AutoGK to convert from VOB->AVI results in slow-motion video
By WebMaximus in forum Newbie / General discussionsReplies: 5Last Post: 10th Feb 2012, 14:49 -
Slow motion at least 1 minute long clips?
By owen bryan in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2010, 22:08 -
Virtualdub-like slow motion for x264 clips?
By spinmonk in forum EditingReplies: 15Last Post: 19th Sep 2009, 13:33 -
Converted mkv has extremely slow audio
By PandaShake in forum Video ConversionReplies: 5Last Post: 4th Jul 2009, 04:15
