Hi all,
Hope someone can help me with a problem I'm having with Adobe Encore.
Basically, over the past year I've been making small movies in Adobe Premiere and now that I have enough, putting them all into Encore to make the DVD.
My first choice was to have a DVD with no menus, simply play them in order as they were made - simple right?
Well it plays them in order fine, until you try to go to the previous chapter. If you click on previous chapter, it goes to a chapter that wasn't the one before it.
Basically, Encore has added them to the DVD in a weird order (not as shown on the timeline) and is all jumbled up, it links correctly going forwards, but it either doesn't work when you click on previous chapter or it follows a bizzare order.
After this happened the first time, I decided a menu would probably sort out the issue. So I made a simple menu (that I didn't really want), made sure the timeline was correct..... but I still get the same issue.
Can anyone help with this issue at all?
Thanks in Advance
Phil
Results 1 to 1 of 1
Pioneer DV 585a playing several new movies in wrong chapter order.
By snirpens in forum DVD & Blu-ray PlayersReplies: 0Last Post: 14th Apr 2012, 14:52 -
Adobe Encore
By mobie29 in forum Authoring (Blu-ray)Replies: 33Last Post: 6th Jan 2011, 02:09 -
Chapter Separators with Adobe Encore
By LAM_ in forum EditingReplies: 2Last Post: 22nd Oct 2008, 11:23 -
Adobe Encore Help
By Entengdigital in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2008, 03:36 -
Adobe Encore DVD black level wrong
By evoshandor in forum Video ConversionReplies: 14Last Post: 15th Oct 2007, 09:17
