Hello.
Just joined this forum, need a little help. Heres my problem...
I use Cucusoft Pro to convert my files from AVI to DVD (VOB)
But once i've burnt the VOBS to a DVD i've noticed, for example when i burned the movie 'The Descent' it consisted of 4 VOB files, around 1GB each.
When watching the movie on the TV where it changed to the next VOB file the picture would do a slight 'JUMP' nothing to bad but ever since i've wanted to know if there's a way to stop that?
I once tried merging to VOB files together with VOBMERGE so it'd be one big VOB file and then using a different program to get my IFO's & BUP's then converting it into an ISO file and burning it as an Image but i must of split itself again into seperate VOB's since it still did a JUMP on change!!!![]()
I'm kind of finding it hard to explain but i've tried my best. hehe
Any feedback will be brillient
Thanks![]()
Results 1 to 10 of 10
Use better software ? I have never had this type of problem using ConvertXtoDVD, or using a manual approach.
Where these avis single files to begin with, or multi-part files ?Read my blog here.
VOBs have a maximum size of 1GB as a part of the DVD format. You can see the DVD format in 'What is' DVD to the upper left. <<<<<<<
The 'jump' likley has to do with the way the video is authored to the DVD format. Someone else here can probably explain this better.
And welcome to our forums.
guns1inger, how long does ConvertXToDVD take to convert a say 750MB AVI file to DVD?
Nero to burn my DVDs
Yeah, i use VideoLAN to playback on the PC and it jumps when changing to the next VOB
Every movie i've burn to DVD and played on my TV does it. you're right prolly is the software. but i don't know many programs? can anyone name any programs which are good and can convert a movie in around 2.5 hours?
Can't Jump After Burning DVD
By analytalica in forum Newbie / General discussionsReplies: 11Last Post: 17th Mar 2013, 09:30 -
WMV jump seeking
By 1031982 in forum EditingReplies: 0Last Post: 30th Nov 2010, 17:08 -
Frame Jump Every Second With Deinterlace ?
By blewyn in forum Video ConversionReplies: 32Last Post: 18th Nov 2010, 11:12 -
Jump right to movie
By raschko in forum Authoring (DVD)Replies: 0Last Post: 28th Oct 2007, 16:48 -
GfD: how do I jump to chapter 1?
By AlanHK in forum Authoring (DVD)Replies: 2Last Post: 9th Aug 2007, 06:10
