In American household wiring, which is the "hot" wire -- black or white?
TIA!!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
http://www.leadsdirect.f9.co.uk/mainswiring.htm
Look down at the bottom.
Originally Posted by Xylob the Destroyer
in the USA - black is always hot , except in some switch legs (the leg to your light switch) in which (in 1 way , 2 way or 3 way +) either wire COULD be hot depending on switch position ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
White or gray is neutral (or grounded current carrying)
Green is ground (or grounding, non-current carrying)
Most other colors are hot (or ungrounded current carrying).
In switchlegs the white wire is used as an ungrounded current carrying conductor so both white and black should be considered hot."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
I'll go with Gadgetguy on this one for the most part.
But hot can almost be an irrrelative term in AC and when going behind others work don't assume anything. (switches with travelers especially) And once you get inside a device or its controls all bets are off. As far as wiring the average device if everything is "normal" put the green wire on the green screw, the white wire on the white/silver screw and the black wire on the brass/yellowish screw. A good solid mechanical connection is a good electrical connection.IS IT SUPPOSED TO SMOKE LIKE THAT?
over the air antenna w/ pre installed wiring from cable
By carlos28355 in forum DVB / IPTVReplies: 4Last Post: 26th Sep 2011, 00:10 -
Electrical problems
By Nelson37 in forum Newbie / General discussionsReplies: 7Last Post: 30th Jun 2011, 13:16 -
Wiring configuration for HTPC
By Haopengyou in forum Media Center PC / MediaCentersReplies: 1Last Post: 19th Apr 2011, 21:03 -
5 Pin DIN Plug - Wiring Diagram ??
By 12Quidkidinnit in forum AudioReplies: 7Last Post: 11th Sep 2010, 21:40 -
Electrical Requirments for Church Sound Stage Setup
By GT Music in forum AudioReplies: 4Last Post: 6th Feb 2009, 15:45
