Hi,
I use 'ffmpeg' to convert a .AAC file to MP3 format:
(see at the end the full output)Code:bash-3.1$ ffmpeg.exe -y -i in.aac out.mp3 && mplayer.exe out.mp3
The output audio file is playable but too slow.
I've tried to change the '-ar' and '-ab' parameter, but it doesn't seem
to have any effect:
(no effect, see below)Code:bash-3.1$ ffmpeg.exe -y -i in.aac out.mp3 -ar 32000 -ab 15 && mplayer.exe out.mp3
How can I change the 'speed' of the music after convertion with ffmpeg?
(and get a playable MP3 file)
Regards,
Petru
1. Simple convertion : output audio file too slow
2. Changed the '-ar' and '-ab' param - no effect!Code:bash-3.1$ ffmpeg.exe -y -i in.aac out.mp3 && mplayer.exe out.mp3 FFmpeg version SVN-r5804, Copyright (c) 2000-2004 Fabrice Bellard configuration: --enable-mp3lame --enable-faac --enable-faad --enable-gpl libavutil version: 49.0.0 libavcodec version: 51.10.0 libavformat version: 50.5.0 built on Jul 25 2006 07:42:27, gcc: 3.4.4 (cygming special) (gdc 0.12, using dmd 0.125) Input #0, aac, from 'in.aac': Duration: 00:00:03.9, start: 0.000000, bitrate: 15 kb/s Stream #0.0: Audio: aac, 8000 Hz, mono, 15 kb/s Output #0, mp3, to 'out.mp3': Stream #0.0: Audio: mp3, 8000 Hz, mono, 64 kb/s Stream mapping: Stream #0.0 -> #0.0 Press [q] to stop encoding [mp3 @ 0x72e550]lame: output buffer too small (buffer index: 321, free bytes: 1983) size= 138kB time=17.7 bitrate= 64.0kbits/s video:0kB audio:138kB global headers:0kB muxing overhead 0.000000% MPlayer dev-SVN-r19147-3.4.4 (C) 2000-2006 MPlayer Team CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ (Family: 15, Model: 35, Stepping: 2) CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE SSE2 Playing out.mp3. Audio file file format detected. ========================================================================== Opening audio decoder: [mp3lib] MPEG layer-2, layer-3 AUDIO: 8000 Hz, 2 ch, s16le, 64.0 kbit/25.00% (ratio: 8000->32000) Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3) ========================================================================== AO: [win32] 8000Hz 2ch s16le (2 bytes per sample) Video: no video Starting playback... A: 15.6 (15.6) of 17.0 (17.0) 0.1% Exiting... (End of file) bash-3.1$
Reply »Code:bash-3.1$ ffmpeg.exe -y -i in.aac out.mp3 -ar 32000 -ab 15 && mplayer.exe out.mp3 FFmpeg version SVN-r5804, Copyright (c) 2000-2004 Fabrice Bellard configuration: --enable-mp3lame --enable-faac --enable-faad --enable-gpl libavutil version: 49.0.0 libavcodec version: 51.10.0 libavformat version: 50.5.0 built on Jul 25 2006 07:42:27, gcc: 3.4.4 (cygming special) (gdc 0.12, using dmd 0.125) Input #0, aac, from 'in.aac': Duration: 00:00:03.9, start: 0.000000, bitrate: 15 kb/s Stream #0.0: Audio: aac, 8000 Hz, mono, 15 kb/s Output #0, mp3, to 'out.mp3': Stream #0.0: Audio: mp3, 8000 Hz, mono, 64 kb/s Stream mapping: Stream #0.0 -> #0.0 Press [q] to stop encoding [mp3 @ 0x72e550]lame: output buffer too small (buffer index: 321, free bytes: 1983) size= 138kB time=17.7 bitrate= 64.0kbits/s video:0kB audio:138kB global headers:0kB muxing overhead 0.000000% MPlayer dev-SVN-r19147-3.4.4 (C) 2000-2006 MPlayer Team CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ (Family: 15, Model: 35, Stepping: 2) CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE SSE2 Playing out.mp3. Audio file file format detected. ========================================================================== Opening audio decoder: [mp3lib] MPEG layer-2, layer-3 AUDIO: 8000 Hz, 2 ch, s16le, 64.0 kbit/25.00% (ratio: 8000->32000) Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3) ========================================================================== AO: [win32] 8000Hz 2ch s16le (2 bytes per sample) Video: no video Starting playback... A: 15.6 (15.6) of 17.0 (17.0) 0.0% Exiting... (End of file) bash-3.1$
Results 1 to 1 of 1
Slow motion with ffmpeg?
By charlesdavison in forum ffmpegX general discussionReplies: 2Last Post: 31st Aug 2010, 09:07 -
Mencoder // ffmpeg flv file Audio-video sync problem
By krishnareddy in forum ffmpegX general discussionReplies: 5Last Post: 26th Apr 2009, 09:13 -
ffmpeg wmv -> flv convertion problems
By rolikoff in forum LinuxReplies: 3Last Post: 17th Mar 2009, 04:39 -
Merging audio file and video file using ffmpeg
By suresh3484 in forum ffmpegX general discussionReplies: 3Last Post: 17th Aug 2008, 21:20 -
By suresh3484 in forum ffmpegX general discussionReplies: 0Last Post: 27th May 2008, 03:05
