    Sep 2004
    Australia
    Anyone know a program that can cut out any scene I want in rm,rmvb files? I know RealMedia Editor can do that but I don't want to use it cause it comes with Helix Producer. I just want that simple small program
    Jul 2006
    Somewhere
    You should try to use Womble MPEG Video Wizard. It supports DirectShow Filters. and it's very simple and useful.
    Before that, you should install the plug-in 'realalt' at first.
    https://forum.videohelp.com/viewtopic.php?t=289782&highlight=cut+rmvb
    mpeg video wizard is not a simple small program...and will reencode to mpeg...
    Dec 2004
    Australia
    Well I would have suggested R.E.V.E. again, but Shaorin said no Helix Producer and R.E.V.E. is just a GUI for rmeditor from Helix producer. Won't do much by itself.
    Nov 2008
    Jamaica
    You need
    1: MKVtoolnix to cut (& join sometimes), then....
    2: MKVExtractGUI to extract audio & video (rename .ra audio file to .rm)...
    3: RMMuxer to remake .rmvb file
    https://www.videohelp.com/tools/MKVtoolnix
    https://www.videohelp.com/tools/RMMuxer
    N.B. RMMuxer may not work with .aac audio files
