Hi,
I've got about 251 quicktime trailers I am trying to convert to DVD format, MPEG2. A lot of them are the new 'HD' trailers from www.apple.com/trailers. I use TMPGEnc to convert them, but when I try doing a batch encode of about 8 at a time, TMPGEnc constantly freezes after the first one or two when it gets to 100%. It just completley locks up and wont go any further.
I have installed that Quicktime Reader plugin. It works fine for doing one at a time, but I got a lot of trailers I want to get off my hard drive.
Is it because of the new HD format they are encoded in? or is there another good program to convert them to dvd format?
I use Adobe Encore 1.5 for the dvd authoring, but that only accepts files 720*576, otherwise I would just import the quicktime files directly into that.
Thanks for any assistance!
-HamishT
The freezing or lock up, is a known problem with TMPGEnc batch program. I don't think they will ever fix it. If you need a batch encoder, you will have to use something else. CCE, Canopus ProCoder, etc. Here is a whole list of other encoders.
https://www.videohelp.com/tools?s=40#40 -
Ok, I downloaded CCE SP Trial, but I get an error message straight away:
"GdipLoadImageFromFile failed :3"
anyone else have any particular software they could recommend?
Just for testing, I imported an HD trailer into Adobe Premier, it says there is no sound file lol.
Date Created - Batch Encode
By conandrum in forum Video ConversionReplies: 15Last Post: 14th Nov 2013, 15:57 -
Need To Batch Encode 78 MPEG2 Files
By hech54 in forum Video ConversionReplies: 7Last Post: 31st Dec 2010, 07:10 -
RipBot264 keeps freezing during encode
By cjbrown80 in forum Blu-ray RippingReplies: 15Last Post: 16th Feb 2010, 10:14 -
Simple batch encode H.264
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2009, 12:32 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 20:52
