    Jun 2005
    Vermont
    OK, here's the problem. I have an ISO file that's to big to fit on 1 DVD. And, I do not have a dual layer burner, so I want to be able to convert it to VOB's so I can put in to DVD Shrink. I've looked at all the converters on this site & can't find anything that will do that. Unless there is some other method to achieve what I'm trying to do. Any ideas would be greatly appreciated.
    USA
    You could try ISOBuster to extract it to a DVD file. Did you try 'Open disk image' with Shrink? It should be able read an ISO.
    Jun 2005
    Vermont
    Thanks, I'll try those. It'll take a couple of days till I can get to it.
    Jun 2005
    Vermont
    Just an update. The "Open Disc Image" in Shrink worked perfectly. Thanks!
