Fujitsu Siemens
Produkt: 3504050448
http://www.fujitsu-siemens.com/support/downloads.html
Fujitsu siemens will not answer me. It is to old?? Bad support.
Zusätzliche Hardware: I have problems with my mothetboard K7T266pro2
(MS-6380) version 3
(AMD 1900+)
Orginal installation CD.
Sound driver avance ac97 via (r) audio
With my product series 3504050448 I can come to Fujitsu siemens download page
Added and Downloaded Uppdated BIOS and
SOUNDTREIBER FÜR ALC201/65x SOUNDCHIP VER.5.10.00.5760 .
Betriebssystem: Windows XP Professional
Fehlerbeschreibung: I have problems with my mothetboard K7T266pro2 (MS-6380)
version 3 Sound driver.
My problem is
1 Manual for sounddriver
2 When I have headset with mic and try, in controlpanel, sound and "voice"
test program, It does´t work. when I mark "(bozz?)" it registreit in
recording but in playing mode I cant change volym. It doesn´t sound or it
begins to round echo very hight.
I cant hear my voice in headset like it should do when I talk.
Should I download
Driver - Via Apollo Pro266 (VIA VT8633) + VT8233 - Scaleo 600 AXP19 1 512MB
VIA 4 IN 1 DRIVER
Date: 16.11.2004
Version: 4.53V
Manufacturer: VIA Technologies
What is this driver? And how do I do? Should I klick on VIA4in1.exe? and it will change to a better driver automatic?
Can you help me get the right drive or tell me what is wrong
Please help me
Tommy
A little criptic ... but you should head over to msi first .
http://www.msi.com.tw , and search for MS-6380 , it will lead to the driver download page eventually .
The two available
VIA AC97 PCI Sound Drivers , and VIA Chipset 4in1 Drivers
You should be in admin account to make driver change's ...
Should your system be already using the 4in1 package from the motherboard cd , it is a good idea to atleast update them ... you simply run it , and xp will decide if they are better than those already running .
As for the audio , somewhere it was mentioned about not disabling the onboard audio in the bios if an add on pci card is installed ... a little strange , under normal method's it is disabled ...
Consult the mother board manual as to how to enter bios ... not all pc bios's are the same .
Download the audio package from msi , and run it ... again , xp will make it's own mind up about thing's and reboot the pc when done .
My advice would be update the 4in1 first and reboot , and check audio .
If audio still out , go into control panel , and uninstall the sound chip driver's ... say no to restart , then go to add/remove program's and remove the program related to the audio chip (mine just has the audio driver setup which I'll assume will take out vinyl deck app that mine come's with) , say no to any restart request's , then run the new audio package ... now let it restart , and see how it gose .
Of course none of this will help if there is an actual problem with the audio chip on the motherboard ...
If you get down to this last problem , disable onboard audio in bios ... and grab a new pci sound card , just make sure it is fully compatable with your current os .
It's also a good idea if people refer to the motherboard manual's when it come's to installing addon card's ... just because there is a free slot or two , dosent exactly mean you can just shove one in it ... These slot's are paired up .
If motherboard onboard video in use
Agp slot and pci1 cannot be used .
If onboard n/a or disabled and agp is used
Pci1 still cannot be used (shared resource's)
Pci2 and Pci3 share again , so only one slot can be used .
For those with "full" motherboard's ...
Pci4 and pci5 share again , so only one can be used .
Doing it any other way risk's not only system resource conflict's , but could cost you either replacing the addon card , or worse , the motherboard .
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
fujitsu fmv-biblo nb8/90d
By ieh4f in forum Newbie / General discussionsReplies: 0Last Post: 15th Jul 2009, 12:36 -
Fujitsu Siemens Pocket LOOX
By mgowins in forum Video ConversionReplies: 2Last Post: 9th Jul 2009, 17:09 -
I just got a Fujitsu PDS-4233E-H Plasma TV (Used) Can I view HD with it?
By videocheez in forum DVB / IPTVReplies: 10Last Post: 7th Dec 2008, 12:02 -
fujitsu amilo m1437g
By Mr anderson in forum ComputerReplies: 1Last Post: 11th Sep 2007, 13:25
