Hello fellas,I am trying to rip a 2 disc video from a cd-r.I searched and came up with this.https://www.videohelp.com/forum/userguides/141726.php
But I want to rip the 2 cd-r's into my harddrive and make them into one dvd+r.
Im to familiar on how to that....can someopne help..........
please let me know what tools i will need and steps to take.......thank you
I'm assuming this a vcd.
Use isobuster and you'll get 1 mpg file for each disc.
The simplest way to do this is to use Tmpgenc Dvd Author and take the two mpg files and simply put them back to back in the same title:
example:
title 1
mpg file 1
mpg file 2
That way they should play back to back seemlessly.
Since they are vcd they can be put into dvd format. The beauty of TDA is it will only convert the audio (to 48khz the dvd spec - vcd is 44.1 khz or the rate of a normal audio cd). The video will remain unchanged.
You can download a trial copy of tda to use. Just click on the highlighted "tmpgenc dvd author" link above to find out where to get it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If the original files are avi's, then you will most likely ending up getting audio sync issues.
My experience has shown that is much less work and time consuming to get a standalone that can play Divx/avi. Then all you have to do is burn the files onto a disc as data and play.Google is your Friend
Ripping apparently unfinalized disc?
By wetcamelfood in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2012, 15:27 -
Ripping tv series disc
By pearce88 in forum DVD RippingReplies: 6Last Post: 1st Oct 2010, 11:24 -
ripping audio of a DUAL DISC
By efiste2 in forum AudioReplies: 3Last Post: 31st Aug 2008, 13:06 -
Any advice for ripping a badly scratched disc?
By Bix in forum DVD RippingReplies: 27Last Post: 6th Jun 2008, 13:11 -
Ripping 2 disc set with Fairuse Wizard 2
By acid_burn in forum DVD RippingReplies: 2Last Post: 25th Mar 2008, 15:12
