I am a complete novice as regards copying DVDs. I have a Panasonic DVD recorder, a Pioneer Burner 111D, and have TMPGEnc Author. I have managed to copy one DVD with no problem which is great.
I have a friend with practically the same equipment but she says that her AC3 plug in does not work as she hears no sound when she edits. I don't think I have the plug in.
Can anyone enlighten me?
Results 1 to 10 of 10
Three possibilities:
1.She didn't register the plug-in: http://tmpgenc.pegasys-inc.com/en/product/tsp_ac3.html
2.She doesn't have the correct TMPGEnc version(see above link).
3.She doesn't have an AC-3 decoder,do DVD's play ok on her PC? -
Yes they do play OK as she has copied something for me before I got my burner. I don't know why she needs it really.
Actually, I think it worked at first but doesn't now.
Do you really need it or is it just a gimmick? -
A little clarification. You need it if you want to listen to AC-3 audio while authoring and/or if you need TDA to convert your audio to AC-3. If your audio is already AC-3, TDA will pass it through OK without the plug-in.Originally Posted by MOVIEGEEK"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
This is my point. I think she needs it for that very thing. I am going to get to grips with the whole program before I get into technicalities.You need it if you want to listen to AC-3 audio while authoring
Thank you for the welcome!
Using the plug in is easier but there are work arounds that I've used. The simplest is to encode your mpg file with MP2 audio and use ffmpeggui to create a seperate AC3 audio file. Load the mpg and set your chapter points listening to the MP2 audio. After you're done setting chapter points select the AC3 file for your audio.Originally Posted by hech54"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
I've done almost that same thing in the past too....but making a seperate PCM file. The plugin was worth the money...at least for me.
What is this plug??
By trunksu in forum Newbie / General discussionsReplies: 3Last Post: 1st Feb 2011, 05:09 -
quicktime plug in for 10 bit (4:2:2) Uncompressed
By privor in forum MacReplies: 1Last Post: 24th Nov 2008, 12:29 -
MS Media Player plug-in
By AndreL in forum Software PlayingReplies: 1Last Post: 7th Jun 2008, 16:01 -
Problem with NeatVideo plug-in...
By beckmen in forum RestorationReplies: 0Last Post: 10th Mar 2008, 18:50 -
RIAA tries to pull plug on Usenet
By stiltman in forum Off topicReplies: 3Last Post: 19th Oct 2007, 22:21
