Hello there,
I am new to the whole DVD/Film and Final Cut Pro so need some advice!
History:
I have some old footage from video Hi8 tapes that a friend has put onto DVD's for me using his panasonic DVD recorder. I want to now import the footage into Final Cut Pro to edit and cut and make into a smart DVD's with menus and such like.
I have taken the VIDEO_TS file from the DVD and place it onto my hard drive of my iMac G5 with 60gig of space and 1.5GB of memory.
The VIDEO_TS file is 2.6gig
Problem:
I tried to import the VIDEO_TS file into Final Cut Pro but I get a general error message and only a small bit of the file imports. I know a general error is vague but can any advice be offered? Such as do I need more space for a 2.6gig import? Is my memory sufficient?
I hope someone can help??
Cheers Laura![]()
As a workaround:
MPEG Streamclip - drop the first VOB onto the app and, when it asks if it should open all of them, "ok" this. Then export to DV. Anticipate 15GB of hard drive space required per hour of footage for the DV. FCP will then have no problem using that DV footage. -
I have tried the MPEG stream clip..... it imports into that correctly and it takes all the VOB's and I can see all the footage, when I come to export it to DV not all of it is converting. Do I have to do each VOB individually?
Am I doing something wrong? This is so frustrating!
Is it the way I recoreded the footage onto DVD from a video 8 tape using a panasonic video recorder?
Cheers -
It sounds to me that there are time code breaks in the video which is common with DVD recorders. MPEG Streamclip should have given you a message when you opened the VOB set that time code breaks were present. There is a menu item in Streamclip to fix the breaks. Do that. Then do it again to see if it worked. If there are no more breaks then the export will work well.
If it doesn't work, do you have Toast 7? -
or ffmpegx for that matter, and do the same thing
as you would have with MpegStreamclip?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Hello,
My friend has used TMPGEnc on a windows comp to remove the chapters from the DVD and then re-burned to a DVD. I can now import it all into iMove!
How can I do this myself on a mac?
What program can I use?
Why is this such a problem on the mac?
Hope you can help?
Cheers!
Final Cut X
By Tom in HD in forum MacReplies: 1Last Post: 29th Oct 2011, 09:35 -
Why Mac? Why Final Cut?
By codemaster in forum EditingReplies: 26Last Post: 15th Mar 2011, 00:17 -
Final Cut - HD looks stretched
By cupaT in forum Video ConversionReplies: 9Last Post: 26th May 2010, 22:01 -
16:9 in Final Cut Pro
By malibu in forum MacReplies: 2Last Post: 5th Jul 2008, 08:41 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
