While converting an AVI to SVCD using TMPGEnc, I get a "floating decimal point" error and the application stops at 37%.
I have tried SVCD and VCD and get the same error at the same point. The preview plays the entire clip.
I was thinking I could cut out the "bad" part, but I don't know of any AVI editing applications. I have used MPEG Scissors with great success, but it does not support AVI.
Any ideas?
Thanks, Bob
I use VirtualDub to edit AVI files, and it's amazing. Let's you cut frame by frame... try that.
Use "vdub-mp3-freeze.exe" to find bad frames, it makes a log for you, then cut them at keyframes.
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 18:47
