I have a 5th gen iPod video 60gb and a couple of months back I purchased a TV-out cable. It worked fine but there's some serious overscanning going on. It seems like I'm missing up to 1/3 of the screen, hence I haven't used it since. I was wondering if perhaps this problem was specific to my iPod and/or cable. Is anyone else having this same problem?
Hi,
Do you have your iPod set to output in widescreen? I have mine set to output in widescreen even though I only have an old 4:3 crt 28" tv, It displays properly like my DVD player would. What resolutions are you encoding your movies at ? Are you using H.264 or regular MPEG-4? Getting good quality for TV Out takes a little more work than encoding just for the iPod screen. If you are using a regular 1/8" AV cable you will have to swap the red and yellow Composite jacks as well, but you probably already knew that since you were getting somewhat of a picture. -
Believe it or not, I didn't have to swap the red and yellow jacks. I'm using a very basic 768kbps, 320x240 H.264, but that's beside the point because I'm not terribly concerned with picture quality now. I just want to see the entire frame and not have the outside borders clipped. I tried outputting as both widescreen and 4:3 with the same result.
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 01:04 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 21:56 -
any Ipod experts? way to restore lost music on Ipod
By scustalow in forum Portable VideoReplies: 2Last Post: 9th Jul 2008, 01:56 -
IPod nano with video and IPod touch
By SingSing in forum Latest Video NewsReplies: 0Last Post: 6th Sep 2007, 11:11 -
Videora iPod Converter (DVD to IPOD)
By Denman007 in forum DVD RippingReplies: 0Last Post: 15th Aug 2007, 20:06
