I'm wondering is there is a capture card that will allow a higher quality capture than my S-video input. I record quite a few things from DirecTV (HD broadcasts) and was hoping to upgrade my quality. Is there a capture card that has HDMI or DVI inputs, or are we still ways from that? What other options might there be?
Thanks in advance
I don't think they would want you to capture with HDMI or DVI, so not that I'm aware of.
But you can get a HDTV capture card that might work for HDTV streams, depending on your source. You can go to 'Capture Cards' to the left and start with 'All Digital TV' for starts, or refine it depending on the source video.
There are also HD capture cards that work with HD Component Analog (Y-U-V) and with HD-SDI connections, but they're usually for Pro editing stations (Apple FCP, AVID Composer/Xpress, etc). I don't think that's what you're talking about though ($$$).
How to capture gameplay from XBOX360 to AVERTV capture card
By Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 21:16 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
