is there a program to remove this text from movie, as its all way through it
SEARCH!
https://forum.videohelp.com/viewtopic.php?t=300038&highlight=remove+subtitles
or type remove subtitles in the search box here above for several more useful tips. -
If it uses a separate subtitle file, yes, easy. If the subtitles are burned into the video, very difficult and probably not worth trying.
Let me guess... You found movies on P2P, but they all got French hardsubs?
Answer: search HARDER!
How do I remove unwanted text in movie
By rocks911 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2011, 10:35 -
.dv movie project conversion to MPEG-2 with video text
By RL in forum ffmpegX general discussionReplies: 1Last Post: 30th Jan 2011, 17:39 -
Create scrolling text effect for Movie Credits using avisynth and png image
By wiseant in forum Newbie / General discussionsReplies: 6Last Post: 13th Sep 2010, 02:21 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38
