recently, i changed my burner to a Lite On DVD burner. every since i've made the change i just can not get dvd movies burn. I can get dvd iso's burn but not movies. I'm using Nero. I know with nero, you normally pick the dvd videos section in the wizard and choose the ISO tab and uncheck all those settings that are checked and you're good but the dvd still ain't playing. I have an old Toshiba dvd player. Obviously the dvd is playin on the pc. So i know its working. Please someone help me[/quote]
Results 1 to 11 of 11
How's My English?
yea that did not work either. i normally use dvd-lab pro to author my dvds. i tell it to compile and then i use what was placed in those folders and burn
How's My English? -
i ran out of dvds so i wasn't able to try.
i'm going to get more and tryHow's My English? -
what? you lost me there. Can you elaborate on that. I think i know the problem with nero. I have to put it in the joilet setting which i'm unable to set for some reason and i'm wonder if that might result in the dvd burner that i have.
How's My English? -
There is a finalize check box under Burn that can be checked to close the disk to further writting. Bit setting or booktype can be written by some DVD burners that will change the DVD +R to DVD ROM which will make it more compatible. It has been a long time since I fooled with this stuff, so I may have the terms a little off. I don't think you need to fool with the Joilet setting. Just use the Nero wizard and all the settings should be correct.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
