I went to convert an AVI I have to DVD, and when I pull it up in AVI2DVD, there is no Audio stream to select. How can I fix or get around this? It has sound, but the stream does not show up in AVI2DVD. How else can I burn this AVI to DVD. I tried using Nero, but it cut off the last 20 minutes???!! The file is only 560MB, So I should be able to do loads to it and still fit onto a standard DVD. Please help..
Take out EVERY LAST punctuation in the filename. The program is VERY sensitive to parens, extra periods, brackets, dashes, and so on.
and the erros msg is???Originally Posted by xfile102
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 17:42 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27
