I have a .avi file that is around 138MB. It's 22 mins of video. Using Virtualdub, I cut out an 18 second clip that I liked. Now I want to save this as an .avi file ....... every time I try to save, it processes for a couple seconds and then outputs a 390MB file!!! I have tried the "save as" function as well as some others. All the same. I tried switch to direct stream copy. No change. I'm not really good with this piece of software, so some help would be great! Thanks!
If you'd left it as default, it will be outputting the file as "RGB (Uncompressed)" which takes up loads of space. Ensure that you have "Direct Stream Copy" enabled under both audio and video menus, and it should work. Not sure why it didn't before, as you said you had tried it, but perhaps something went wrong.
Give it a shot again and let us know.
Good luck!
Cobra -
Try this :
Menu Video
Select Range
set Direct Stream Copy Audio + video
Save as AVI
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 17:25 -
Reformatted..now all output videos with XMediaRecode are too large
By smackyourfupa in forum Video ConversionReplies: 2Last Post: 25th Nov 2011, 16:34 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 4th Mar 2010, 23:50 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 18:27 -
VirtualDub Output Too Large
By solarblast in forum EditingReplies: 2Last Post: 26th Dec 2007, 20:30
